If you dim light does it consume less electricity?
Go to solution Solved by LAwLz,
It depends on the dimmer.
Old dimmers worked by being a variable resistor (a rotary rheostat). Those dimmers and light bulb combos will always consume the same amount of power because the dimmer dims the light by using up more or less power themselves (by being more or less resistive). In other words, if you dimmed the light, the dimmer itself would get hotter because that energy that didn't get sent to the light bulb was turned into heat instead.
If you had a 60-watt light bulb and dimmed it down to 50%, the dimmer would use 30 watts of power and produce 30 watts of heat.
Modern dimmers work by essentially turning the circuit on and off very rapidly. As a result, it ends up consuming less energy.
Unless you happen to have a very old dimmer, dimming your light do end up consuming less power.
If you dim domestic lights using a standard dimmer switch, do you actually consume less electricity?
Yes.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB /
TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
Dimming works by either reducing voltage (DC), by rapidly turning it on/off (PWM e.g. LEDs) or in the case of AC by reducing the amount of AC cycle that reaches the light.
This means that either Watt = Voltage x Amps is reduced or the amount of time the light is actually on is reduced. And since the electricity you pay for is Watt x Hours (i.e. Wh) reducing either Watts or Hours will reduce the amount you have to pay.
Just now, htimsenyawed said:
Interesting. I like my IoT bulbs because I can dim them without needing to fish new Romex with that 4th wire. Do they function the same?
Fourth wire?
Network:
                         │                        ╚═ Jesta Cannon*
Retired/Other:
An LED can be dimmed by either rapidly turning it on and off or by reducing current, both of which doesn't need more than power and ground. You're probably thinking of PWM fans, which have power, ground, tach and a PWM wire.
@htimsenyawed
Even though the dimmer has 4 wires, doesn't mean you send all 4 to the device that is being dimmed. The Ground and Neutral wires will all tie together. The Hot (from your circuit breaker) will connect to the black wire on the dimmer, then the remaining wire(s) on the dimmer (brown, red, or black depending on brand/model) connects to Hot (black) on the device you're dimming. (all based on NA wiring colors)
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
8 minutes ago, htimsenyawed said:
I have no idea what a PWM fan is. Can you explain?
A fan whose speed is controlled by pulse width modulation. You can either control a fan's speed by changing its voltage or by using PWM (i.e. voltage remains constant). Those have four cables, two that supply power, one that is used to read the fan's current speed and one that is used to supply the pulses that turn it on/off.
A motor needs a certain amount of power to get going, so voltage controlled fans typically can't go slower than 40% of their max speed before the motor can no longer overcome the fan's inertia and stops. It might get going if you give it a push, but otherwise it'll be stuck in this weird state where it twitches a little but doesn't start to rotate.
A PWM fan, like a PWM controlled LED, rapidly turns power on and off, effectively giving the fan a push at full power every now and then. Depending on how many pushes you give it vs how long power is turned off, you can vary its speed in a much wider range than a voltage controlled fan.
Similarly varying voltage of an LED might have a negative effect on its color temperature. PWM on the other hand can result in visible flicker if the frequency of pulses aren't fast enough (https://www.waveformlighting.com/film-photography/an-introduction-to-flicker-free-led-strip-dimming). If you've ever used an old CRT at 60 Hz or below you know what I mean.
I'm not much an electrician, my buddy was a commercial electrician though. So you're saying that even with a regular 12/3 Romex I can use those switches by tying the appropiate wires together?
Yep.  Typically you only need 4 conductors in a residential 120v application if you A: are installing 3-way switches (2 or more switches controlling the same circuit) or B: want to control separate features of a single device (like a ceiling fan and light having separate switches.)
Primary Gaming Rig:
HTPC/Gaming Rig:
I wonder then how one of my dimmers work, it has multiple steps, and I don't think that can be obtained by just turning it off and on again rapidly
Yes, it can. But as others and I have pointed out along the thread, there are multiple ways to dim. Could be using resistive dimming and switching between concrete resistors. Could be switching between concrete voltages. Could be using PWM and switching between specific profiles.
The way you dim with PWM is by rapidly turning it on and off and varying the relative length off the on/off cycles. If both are the same length, then you're at 50% brightness. If it is off 2/3 of the time and on 1/3 of the time you're at 33.3% brightness. Off 3/4, on 1/4 and you're at 25%. Off 1/4, on 3/4 = 75% and so on.
On 12/20/2023 at 5:01 PM, htimsenyawed said:
Every dimmer switch we sold at the hardware store I worked at (local, not Lowe's or anything) required white, black, red and green (ground). Nothing in my house has the red, so I don't have any dimmer switches.
Edit: I found this example which requires a fifth wire (brown) as well.
not true,  we have 3 wires here mostly, 4 max, and dimmers work just fine.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
44 minutes ago, htimsenyawed said:
I’m not sure which part of that statement was untrue, aside from my misunderstanding of electricity.
im just saying you don't need more than 3 wires? idk how it works,  i just know it does work. 😛
(also no "ground" here,  and no issues... another myth, you don't need ground,  cause everything is already grounded to earth (the planet!) typically! )
¯\_(ツ)_/¯
ps: additional interesting information: electricity also doesn't "flow" thru wires at all - another bs myth kids learn in school >.<
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
1 minute ago, htimsenyawed said:
I'm having a hard time believing this one because of the use of ground rods when doing electrical installations. I know that when I worked at the hardware/lumber supply store, electricians would come in and usually get 3 ground rods for the electrical service.
eh, you need *3* wires,  yes. but you don't need 4.
ground/earth might just be a language issue... very confusing because its the opposite in us vs eu, for example.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
2 minutes ago, htimsenyawed said:
From my understanding of the ground rods, they're drove into the ground/earth and are tied into the electrical system of a house for the grounding of the system. Here is a good article about them that gave me the basis of my knowledge of them.
yes. but - you  don't need that - provided that's the thing you need for a "ups" to work.
in other words, a ups doesn't work here (because i only have 2 or 3?) wires, yet there's simply no issue,  the fuses in the house work just fine.
my electrician literally said "these lines have no ground"  (i think its what Americans call "earth" confusingly...)
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
16 minutes ago, htimsenyawed said:
No, we call them ground as well. And the ground rods doesn't appear to be what you need for just a dimmer or a UPS, but to protect your electrical system from grid surges or electrical storms.
well, as said, i don't have the thing you need for a ups. however dimmers work just fine as said (i had 1 in this room for years)
blackouts, thunderstorms, chinese faulty usb cables... pc is still going strong!  (although it would probably fry with a direct lightning strike anyways lol)
as said, it also does trigger the fuses - which is the important part ("tested" with faulty Chinese power supply)
^ thats not to say i don't like Chinese products,  my favorite  brands are Chinese, like segotep, superflower, zeaginal, colorful... all top tier stuff!
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
