New router download speed way slower than my optical fiber router's
Solved by ChevyW.,
Hi!
I bought a switch, turned off the DHCP in both the second router and the switch. Nothing seemed to yeld a result so my supicions arose about the cable. Turns out it was some cheap-made one delivered by the ISP company so I asked my friend to lent me his brand new one. After doing that, my internet speed went back to normal. So, I didn't really have to turn off anything or configure anything (even though I did) as it was a faulty cable. I went up into the cold attic to look and saw someone severed it a bit, probably on accident.
Have a good day, guys!
