NZXT H5 Flow Hard Drive overheating issues.
On 11/29/2023 at 10:00 PM, flibberdipper said:I'd recommend downloading CrystalDiskInfo and seeing how hot it's actually getting. Hard drives should be fine until like 50C (not great for lifespan but they'd at least function correctly). Also, chances are unless you're using some goofy ass 6TB+ 7200RPM drive it really shouldn't be throwing a hissy fit with dickall airflow.
It's a SEAGATE BarraCuda 2TB and yeah I got CrystalDiskInfo and saw everytime it went to around 50-51C it would shut off. I moved it to the front of the case and it now sits most of the time at less than 30C and has stopped it from abruptly and randomly going on and off. Now the mounting isn't really that secure as it's just mounted with 2 screws to a fan mount but until I think of a more permanent solution it will do.
Thank you for your help and time.
