Help with PC Upgrades (Motherboard and CPU)
22 minutes ago, Emerald108 said:Around 550 for everything if possible? Can definitely go higher if needed, Willing to purchased used things but yeah it's very iffy haha.
As for my workloads, just running a game like Overwatch or Valorant isn't giving good performance, I reach into the 120+ frames but from looking at others with the same GPU it's looking like it is a CPU issue. Currently my PC struggles to have both a game and spotify open at the same time.
Probably worth noting that i'm from Australia so things will be more expensive over here too
OK, I was about to say $550 is a lot for a "budget" CPU/mobo until you said "Australia." Just to make sure, those are AUD and not USD (I'm assuming AUD)?
If you're just trying to go for a CPU/motherboard, I'd probably go for a 5700X and a B550M TUF. That would put you at around $480 and let you reuse your current RAM. If you need a cooler (if you don't have AMD mounting hardware), this should work and raise the price to about $520:
