Old Vesa mount for new TV help.
Solved by circeseye,
2 hours ago, Ridguard said:Is there a way I can tell if the one I have supports multiple tv's?
if you can see the mount on the tv and the mount legs are longer then where the screw is then it might be a 400x400
if the screws are pretty much at the end of the legs then its only a 300x300
fyi this is a good example of a all vesa size mount
https://www.amazon.com/gp/product/B07SMF9SQM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
