Aio sizes and opinions
TW_LANDONKUCHER
I wanted to know if there is a major difrience between 240mm and 280mm aio, also opinions on the NZXT - Kraken 240
Not really - difference in minimal in performance and mainly in aesthetics
NZXT AIO's are good, so I hear
AMD 3600x, 16GB DDR4 3200MHz CL14, GTX 1080, and Ungodly Amounts of Storage
I'd fit the biggest your case allows and what's within budget.
280 will do better and lower noise since you can run the bigger fans at a lower speed.
I havent owned an NZXT cooler since the x61 coolers but i dont hear many complaints about NZXT other than price.
Recent build: Fractal Design - Torrent reviewMeshify C / The 1080TI Strix Noctua modDefine S X58 Xeon build  / Specs: i7-14700KF 5.8Ghz - ASUS TUF RTX 4080 super - G.Skill Ripjaws 32GB 4000mhz CL18 -  Gigabyte Z690 Gaming X d4 - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua D15
Cooling performance is about the same yet the 280mm is a bit quieter due to larger fans moving air at slower speed
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Thickness also plays a part. A thinner 280mm could be less coolant than a thicker 240mm
Not English-speaking person, sorry, I'll make mistakes. If you're kind, maybe you'll be able to understand.
If you're really kind, you'll nicely point that out so I will learn more about write in good English.  🙂
there is quite a difference a 280 Rad has an area of 392 cm² and a 240 just 288 cm² so quite a difference especially because a 360 Rad has just an area of 432 cm². But with a 280 Rad its way more importat that the fans can build up sufficient static pressure wich is harder for 140 mm fans... so all in all a bad 280 rad might be worse/the same as a good 240 rad, but a good 280 Rad  should be better than a good 240 one
If people don't just use default Asetek rad thickness of around 35-40mm.
Spoiler: a lot of people do.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
aio standard is like 28mm use to be 30mm... i heard artic aio are thick thow thats why there the best.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
if you put really good expensive fans on a 280 then ya it would be better but a 360 or 420 probably better then buying expensive 140mm fans...
