Strange noise coming from CPU fan?
Solved by Askew,
Hyper 212 EVO.
The clips that come with it can be used to mount other 120mm fans, from personal experience I recommend the Noctua NF-F12, it's designed for applications like heatsinks, it is very power efficient, quiet and uses good quality magnetic bearings.
There are plenty of other fans that will fit also, have a look around.
Good luck!
Featured Topics
