I need help to choose my AIO cooler
Solved by ImWilly,
5 minutes ago, Shwisqy said:Is the NZXT still better at max fan speed, or does it fall behind?
Well, as the table informs at max fan speed, NZXT Kraken X73 is crushing all of the other AIO, including Arctic and Deepcool
6 minutes ago, Shwisqy said:What about the Nzxt X73 vs the Deepcool LT720?
But on the scenario where the fan speed is set to max 40dB, NZXT lost to Deepcool and Arctic (basically NZXT fan is not designed to be quiet)
That is why if you're looking for absolute raw max performance, NZXT is the clear winner
But if you wanna quieter sound on your PC and not always wanna crank 300W performance on your CPU, Arctic might just be worth a shot
