2 cables between switches = faster?
Solved by Biohazard777,
Depends on the switches used:
If your unmanaged switches lack Spanning Tree Protocol (STP), adding a second cable between them creates a bridging loop. This saturates the network, rendering it unusable until the extra cable is removed.
With STP-enabled unmanaged switches, only one of the switch-to-switch links is active.
- Manageable switches allow port aggregation/trunking for a speed boost slightly below the combined speed of the aggregated ports, accounting for some aggregation overhead.
