Why is nobody requesting the ultimate PBP mode from manufacturers? (LTT plz help)
Go to solution Solved by Gaddy,
I found one !
LG 49WL95C
Screenshot below from its user manual
32/9 screen , 3pbp : 8/9 + 16/9 + 8/9
(1280x1440 + 2560x1440 + 1280x1440)
personnaly I still search that on a 40" 21/9 screen, and not a 49" 32/9, but it looks like exactly what the OP was searching for ?
unless I missed something?
Would you want a 1-2-1 PBP option for ultrawide monitors?
18 members have voted
  1. 1. Would you want a 1-2-1 PBP option for ultrawide monitors?
    • Yes
      8
    • No
    • I don't care
      10
I have been rocking a triple monitor setup with vertical side monitors for the better half of a decade. A couple of years after getting it my father tells me out of the blue that he has had that same setup in his office. After going into detail about how passionate I am about such a setup, he tells me that several of his colleagues are using it as well.
Anyways, ultrawide monitors start being a thing and obviously I want one, and obviously I also want it to have picture-by-picture so I can effectively get the triple monitor setup I am used to out of a single ultrawide. Here we are so many years of innovation later and I have yet to find a single ultrawide monitor that offers the PBP mode I want…
The 1-2-1 PBP mode
1-2-1 PBP
There are so many advantages to this that I fear listing them because long lists are cringe. I'll name two obvious ones though:
That PBP in general is a godsend for ultrawides because not all games look good in a 32:9 aspect ratio, so I would much prefer to get double the fps from rendering half the screen size.
And that most PBP modes available today effectively force you to have your fullscreen application running on either half of the monitor instead of dab smack in the middle of it. I have never tried gaming like that but I can only imagine your neck gets really sore quicker than your partner starts telling you you promised to play for only 5 minutes hours ago.
Am I alone in this?
PC: AMD Ryzen 9 5900X | MSI RTX 3070 | ASUS ProArt B550-Creator | Kingston HyperX Fury 2 x 32GB | Samsung 980 Pro 1 TB | SeaSonic PRIME 600 | Turemetal UP10
Keyboard: WASD V2 105-key | Cherry MX Clear (MX Tactile Grey for space, esc and enter)Tai-Hao Pink & BrightBlue Miami Keycaps
PBP Costs money. And it is a feature you typically found on office monitors like the Dell Ultrasharp series of monitors.
Companies don't see the value (and also can maximize profits) in gaming monitors... but you do get those RGB LEDs that everyone is apparently craving about.
You're not wrong. The thing I just don't get is why I don't see this specific PBP mode on any ultrawide monitor (that already has PBP).
I really hope the upcoming Neo G9 57" will pleasantly surprise me and have this mode, but I fear they will just reuse the PiP/PBP modes that previous Samsung ultrawides used.
29 minutes ago, fanlessfan said:
Am I alone in this?
No. Although I honestly just wanted to divide the monitor into two, but three would have been fine. I was honestly kind of blown away this was not a feature when I went looking for my monitors originally. So I still have two "traditional" monitors sitting on my desk.
Even my son at this point is so used two using two monitors at his desk, I'm not sure he would go to a single monitor either. (So I don't think it's just me being old and not wanting to change.)
i want it, but it's also unrealistic to expect it, the dwf already cost 900usd, if it cost an extra 200usd for some fancy pbp i'd just get a used 1080p monitor. uw is still only 2% of the market.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
For sure expecting this in anything but flagship ultrawides is unreasonable, but keep in mind there already are ultrawide monitors that already support PBP and/or PiP. My main point that I'm trying to get at is that a 50/50 split ultrawide is silly compared to the 25/50/25. And yes of course there would be extra cost associated with adding an extra input but it would be well worth it IMO in cases where we are already paying for subpar PBP functionality.
To expand on what I said above.
For PBP to work, you need a special chip which essentially keeps a video connection with the source and merge the images together for the panel to show.
The problem with it, because there is no market value seen by monitor companies, no chip really delivers the requirements of gaming monitor (no FreeSync, G-SYNC, no unlimited to 60Hz, etc.). So, monitor companies can't use pre-made solution, and making a custom one, well, costs a lot of money. Not to mention that it all needs to keep a super low latency for gaming needs, which just adds more to the challenge.
Businesses don't see the value of making this, too costly. I am sure there is a market for it, but they probably see it as a too small to make it worth it. Most people will see it as a nice to have, and not a must have, willing to spend extra for it.
I think PBP still not matured for gaming usage. So far, I had few monitors that supported it but all half-baked for gaming features where no G-Sync, no HDR and no VRR and etc. once you turn on the PBP.
All only can split screen to half screen. It is functional more for productivity than gaming.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, SONOS ACE, Technics AZ80, Technics A800E, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods MAX, Apple AirPods Pro 2, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile, Tablet & Smart Watch: Google Pixel 9 Pro XL (Obsidian) Apple iPhone 15 Pro Max (Natural Titanium), Apple iPad Pro 11" 2024 M4 (Space Black), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
Although I would like PBP as an option I don't think I would use it as there's too much limitations. I wanted full refresh rate, VRR HDR etc and without them i just rather split my screen using software like DisplayFusion.
PC spec: CPU: RYZEN 9 9950X3D | GPU: SAPPHIRE NITRO+ 7900XTX | MB: MSI MAG TOMAHAWK x870 RAM: G.SKILL TRIDENT Z NEO 64GB (2x32GB) DDR5-6000 30-40-40-96 COOLING: ARCTIC LIQUID FREEZER III 360, BE QUIET! SILENT WINGS 120 & 140mm| CASE: ANTEC C8 | UPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: LOGITECH G502X PLUS WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: GIGABYTE MO34WQC2 2x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
Yeah this does seem to be the case from what I've been able to gather. IMO a flagship ultrawide such as the Neo G9 49" (as well as the upcoming 57") definitely ought to have PBP even if it turns off those aforementioned features. The monitors are already so expensive and luxurious that they might as well double for productivity use. Luckily this already is mostly the case. Unfortunately the PBP modes are usually 50/50 or 70/30 or something like that.
I for one would even be happy with a 60Hz mode when using PBP. It's far from perfect but in my case there will always be scenarios where I would prefer extra screen space next to my full screen application over VRR and HDR. Both in gaming and in productivity.
On an entirely different but almost related note, it sure would be awesome if monitors that support PBP would utilize DisplayPort MST.
Unfortunately DisplayFusion and FancyZones are unable to properly split a screen, so full screen applications will always take up the entire monitor. There are a few exceptions but they are few and often require some degree of hacking to get to work.
Samsung actually reduce the functionality of PBP/PIP. 😅
  • 49" Samsung Odyssey Neo G9
    • PBP in 50/50, 70/30 @ 120hz
    • PIP @ 120hz
  • 49" Samsung Odyssey OLED G9
    • PBP in 50/50 @ 120hz
    • PIP @ 120hz
Yeah. I am fighting to not get my hopes up that the 57" will get 25/50/25 @ 120Hz as well. It would be my ideal monitor. 🥹
Don't put too high hope, as if that 57" is also smart features monitor, then it will only have PBP in 50/50 @ 120hz.
Also you need to have RX 7900XTX to proper handling that monitor as it required DP 2.1 for drive the insanity 7680 x 2160 resolution @ 240hz.
They might have changed it since they undoubtedly had to redesign the entire thing to support the insane bandwidth.
If it has 25/50/25 I will undoubtedly buy it even if I could only push 60Hz (although I'm fairly certain my 3070 would be able to handle 120Hz).
You put too big hope on it. 😅
Anyway wished you dream come true. 😉
  • 5 weeks later...
The manual for the 57" G95NC has been released and unfortunately my dream did not come true 😑
No surprise. PIP/PBP functions is not that advanced yet.
Yeah I'm not surprised either, but they certainly could implement it if customers were loud enough.
There is already a ton of advanced functionality in their PIP/PBP solution:
Unless this same PBP mode also supports VRR and HDR, i don't see a point in it for gaming useage. And currently no monitor that has PBP support can do that.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
  • 1 month later...
This monitor can handle three different sources with PBP. It can definitely do 33|33|33, i don't know about 25|50|25 tho, maybe you just adjust a custom resolution as pleased and voilà? Would like to try it out.
https://rog.asus.com/monitors/above-34-inches/rog-strix-xg49vq-model/
  • 1 month later...
Yes ! I would pay a great lot for that PbP layout.
Honestly I don't think they really try or think a lot about the layouts they propose. There are some ridiculous horizontal splits (on ultra wide monitors).. PiP too is nonsense, hiding part of the screen.
My dream is clearly 1-2-1 on a 32/9 screen, or maybe even better 1-2-1 on a ultra wide 24/10 (6/10+12/10+6/10).
THAT would be useful PbP. Main centered window to focus and work + small windows on sides for discord, OBS, email etc...
Oh and also advertise and promote the use of PbP from a single computer. So nice to use.
This can achieve by using one system only. Microsoft PowerToys - FancyZone can easily do this.
No. FancyZones (and all other similar tools) doesn't work with full screen applications (like games) ; doesn't let you maximize/restore with 1 click on the top-right icon, or with one double click on the title bar.
All those tools require you to drag the window to the right place, and/or to use complex shortcuts. It's much less convenient than what you can do with a real dual screen, or a PbP.
I mean, we have ultra large screen now, 21/9 or 32/9, it seems so obvious to propose a main centered screen + side screens for secondary applications, no ?
So far no, my monitor have PIP or PBP and I also not using it because can be said all implementations lost important gaming features, for example no HDR support and no G-Sync, FreeSync or Adaptive sync support.
I only need split screen during productivity usage and FancyZone already can do a brilliant job. I gaming in full screen only.
