If I disable the RTX 3090 in device manager, does it still use power?
Solved by Kilrah,
Yes it will, and might even use more because there won't be a connection to the driver telling it to idle.
You'll need to use a meter plug to check, not much you can assume.
Featured Topics
1
3
SSGSS ·
Posted in Cases and Mods2 -
8
1
Gat Pelsinger ·
Posted in Programming3 -
5
GanjajoggiBig ·
Posted in Servers, NAS, and Home Lab8 -
Quackers101 ·
Posted in Windows1
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
