Why Are Hard Drives Capacity Less Than Advertised?
Solved by tikker,
Was it this Techquickie perhaps?
It is misuse of prefixes. Giga is the SI prefix defined for the decimal system, meaning "a billion" or 10 raised to the 9th power. If you report that number in the binary system then it appears lower, because you are no longer reporting actual gigabytes, but a base 2 equivalent. Note that it is the same number, just represented differently. 1000 gigabyte is 931 gibibyte. The confusion starts when OSes, for example, start reporting it as 931 gigabyte, since it is technically the wrong prefix.
