Difference Between a OEM PSU & a Regular PSU
The OEM version of a Retail unit typically would have some price cuts aspect to it. For example, the Seasonic S12II Bronze 430w is the retail version the OEM SS-***ET/ES Bronze. At a glance, you would see that the housing is this plain gray finished and that the cables are unsleeved and shorter. It also doesn't come with a power cord. Internally, it also uses cheaper caps (lower temp rated on the primary, and a mix of Teapo, OST, and Su'scon on the secondary) instead of the full 105C Japanese cap on the retail model.
The Seasonic G is the retail version of the SSP-***GT/RT. It may offer the same price cuts as the example of what I said above, but I'm unsure of how much.
Anyways, I'm not sure why PCCG listed as such, but usually a retailer won't market the OEM the same as the retail version (and this assume they are aware of all of this). Unless overlooking something due to my lack of sleep, I believe you are getting the retail model. You could always check up with PCCG to be sure.
