*solved* ASUS TUF Z690 NO POST, WHITE LED, NO VIDEO SIGNAL
On 6/10/2023 at 5:14 PM, apacheap said:Hi guys,
It is my first pc build and I am honestly really sad and worried about this.
Specs:
i7 12700KF
ASUS TUF z690 d4 wifi
GIGABYTE RTX 3070ti
corsair rm850xCrucial SSD P3 NVMe M.2 PCIe Gen3 1 TB
Corsair vengeance lpx 2x16gb
What happened?
So, I was building the PC and I decided to first test everything out of the case on the test bench. I could not post and the white led on the motherboard indicated a VGA problem was on. I got really worried and tried a couple of more times. Then I accidentally touched the "reboot" pins instead of the "turn on" pins with my screwdriver and it posted to bios.
Since i thought that just rebooting it will fix the issue when I put it into the case I went to sleep and continued on the next day.
Today I put everything into the case and got the same error with a white led and no post. I tried rebooting it both with the button on the front panel and with the screwdriver on the pins, but it didn't help.
Troubleshooting:
1) Taking out and inserting the GPU back on
2) Reconnecting all of the PSU cables
3) Trying to post on only 1 stick of ram put in the recommended slot
4) Rebooting the PC with the button and with the pins directly5) Flashing the bios (both with the pins connecting and by taking the battery out)
6) Tryied booting without the GPU at all, it posts but there is of course no video since there is no VGA (second picture, the white led is on but the green for boot is on as well)
Please, someone, help, I am getting pretty helpless here, I do not have a different GPU or CPU to try booting the PC. The part that gets me the most worried is that it did boot randomly yesterday on a test bench after I just randomly touched the boot and reboot pins with the screwdriver.
I just saw you are using a pigtailed PCIE cable to both GPU power ports.. don't do that. use two separate, i think i saw another with the same issue on here with a 3070 recently. if you only have pigtailed PCIE cables. use two.. just don't use the second powerplug.
each power plug can deliver 150watt.. but the cable from the PSU can only deliver 250watt.. so if it wants 300 watt you need 2 cables.
