All possible causes of CRC errors in ADSL connection
2 hours ago, Islam Ghunym said:If I replaced the wire with 16 AWG copper wire which is quite thick, will that fight the interference? or the wires thickness have nothing to do with that? I can do some DIY if it takes to shape something because as I said I am living in a dead country with not so much options to work with.
CAT5e ethernet cabling is generally much much better than what they will use for phone lines, it may help.
Conductor size reduces attenuation (usually negligible difference in a house), the number of twists in the cable is what helps reduce noise. Shielded cable might help, but you need a good ground at one end.
Generally if you can move the cable even slightly further away from the mains cabling it may help and try to avoid it running parallel to the mains cabling if possible.
