I think this is too hot... Help.
Solved by Hinjima,
4 minutes ago, Lanrick said:Hello All!
I want some second opinions on this. I have a Ryzen 9 5900x and a Noctua NH-D15. I was running a stability Cinebench run on it and noticed that the temperatures across each core have a 15+ degree C difference between each core. Running stock options in BIOS so not overclocked. Could this be due to mounting pressure or poor thermal paste application?
Not all cores are equal, some are better than others in terms of thermals and performance. 80c max is pretty good temperature in my opinion during a cinibench run on the 5900x. I see no problems here.
