RTX 4090 failure to POST and power limit = 0
Update again,
聽
The problem is solved.
The solution: I've made the mistake of reading the manual. The cable mod, riser+bracket that I bought did not mention, that the cable they sold with the kit was in fact a Gen3 cable. Asus, does not mention in their mother board manual, that setting the PCI-e behaviour to Auto does not in fact detect what type of device is plugged into it and instead default to Gen4. Meaning the only thing I had to do was go to the BIOS -> select Advanced -> Onboard device configuration (or something like that) -> Find the PCI-e slot I plugged the card in -> set it to Gen3, and voi-fckin-la, it works perfectly.
聽
I'm gonna leave this here, hopefully some other helpless soul in a similar situation might stumble on it
