tomahawk max MSI B450 Tomahawk MAX [BIOS Question]
Solved by 191x7,
57 minutes ago, Waqas409 said:Right now my bios is 1 step lower from where they support the 5000 CPUs.
What if right now i upgrade my Bios to the latest, will my current CPU which is ryzen 5 3600 works or after the latest bios i need a 5xxx CPU?
Please confirm.
Thanks
PS: i have read somewhere that if i do the latest bios, i will not be able to used the 3xxx gen ryzen CPUs eg: ryzen 5 3600
It will work just fine. Tomahawk Max does not loose CPU support with Bios updates. And even if it did, like some other boards with small EEPROM, it would loose only the support for the oldest/weakest models like the Athlon GE or the non-Ryzen AM4 CPU-s.
