4070 strange noise when in game
By
Zibi
in Troubleshooting
in Troubleshooting
Solved by Vishera,
It's called coil whine, it's normal.
It's tied to the FPS - The higher the FPS the more coil whine you get.
In games that don't cap the FPS in the loading screen the FPS in the loading screen can be really high and so is the coil whine.
worstalentscout ·
Posted in Storage Devices0 -
vortexx21 ·
Posted in Power Supplies3 -
Hellowpplz ·
Atheos ·
Posted in Peripherals0 -
11
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows0
