Cheapest replacement key caps for Corsair keyboard
dizmo
I was wondering what the cheapest replacement keycaps for a Corsair mechanical keyboard were? I know you can get Corsair ones for $40 from BestBuy, but I was hoping for something less than half that.
I'm looking to sell a keyboard I got with a PC, that came broken and has a couple of cracked keys.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Which keyboard specifically? Corsair doesn't follow industry standard and uses a non standard bottom row.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Ah interesting good to know! It's a K68 RGB.
Dunno for sure if these will fit K68, I assume they will though since it's from Corsair themselves.
https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/Gaming/Gaming-Keyboards/PBT-DOUBLE-SHOT-PRO-Keycap-Mod-Kit/p/CH-9911060-NA
Welp, nvm, I somehow missed the part you said about knowing corsair pbt ones.
Sorry, 3AM here @_@
Refresh before you reply
https://www.amazon.com/gp/product/B08CB8D2YB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I've got those on my K70, they fit and the pricing is closer to $26 than $40, and it should (in theory) fit the K68 at the same time. No idea if there's anything cheaper, I bought them 3 years ago and forget how I found this listing, but figure it's closer to your target $20 than what you're currently at.
Ahhh yeah I was thinking half the price of the $40, but it was Canadian as well; it's only one broken key. At $30 US (~$45 Canadian) it wouldn't even really be worth fixing, I'd likely just send it off to the recyclers.
