Need advice to upgrading homenetwork from cable to fiber
Solved by Lurick,
2 minutes ago, motomat86 said:Thanks for the response!
So If I treat the ISP Modem all in one as a "modem", and connect a 5Gb+ switch to one of the LAN ports on it (assuming I get maybe 4?) and then just hardwire some access points for wifi throughout? If my motherboard (z690 a-gaming) is a 2.5Gb Port, I would need a new networking card as well I assume?
You want to use the ISP all in one as a modem and router, disable wifi only. Then you can add a switch or two with NBase-T capable ports and you'll be set plus APs where needed. NBase-T supports 1/2.5/5/10
