Hello all!
How are you?
Well, I'd be good, but I have a dilemma. I need some fans for a radiator, but the ones I want are impossible to find.
I'd love to use the Scythe Gentile Typhoons, but they're impossible to find.
So I reach out to you LTT, what do you suggest?
NF-F12s seem to be loud-ish, Scythes are impossible to find, and Corsair SP's are loud...
Quiet is very important, and it's for an 80mm thick Radiator.
Please and thank you :)
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/149649-fans-for-a-radiator/
NF-F12 might be the best bet. I'll see if I can find any cheap-ish GTs.
NF-F12's seem to be the best option.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2000051
first time I've ever heard anyone say Noctuas are loud... :blink: Consider Noiseblocker, maybe. The eloops are good, but in push only. I personally have some BlackSilent Pro 2(s) and am very happy with them. They push through a 20 FPI rad and do so very well. I get a loud "woosh" sound at 12V (noise from air moving through the radiator, not the fans themselves), but they are silent at 7-8V and still move a good amount of air.
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2000094
I have three of the Noctuas on the way, so I'll listen to them when they get here, and report back about them...
There was a video that tested Scythes, Noctuas, eLoops, and a few others with quite a few noise meters, and the Scythes won every single time.
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2000108
Eloops, blacksilent pros.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2007629
Hello all!
How are you?
http://www.frozencpu.com/products/10210/fan-654/Scythe_Gentle_Typhoon_120mm_x_25mm_Fan_-_1450_RPM_D1225C12B4AP-14.html
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2007964
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2039339
Thanks, just got 3 :)
good :D  (Compare them to nf-f12 if you have them, see the difference in noise levels you'll be amazed)
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2039347
I have 3 NF-F12's coming (Got them from the Classifieds for 15 bucks each), and these 3. I've seen reviews of these, showing that the NF-F12's will be loud :D
Also, I got the last 3 of them that FrozenCPU had :P
https://linustechtips.com/topic/149649-fans-for-a-radiator/#findComment-2039439
