Need an advice for fan placement
18 minutes ago, rxtr113t said:But If I mount the aio on the side mount as intake all it's warm air would rush stright thro the entire case alternatively top mounting would suck hot air from the gpu but it's also closer to the back exhaust.
Now I'm confused as to what is the better plan
If you mount AIO on top, it will use air that has mostly been used to cool other parts to cool the coolant.
If you mount AIO at front / side as intake, it will use fresh air to cool the coolant, everybody else inside the case gets the leftover.
If an AIO on top meaning it will suck hot air from GPU, then 3 fans on top would as well, in fact it might be even better at it due to no AIO radiator restricting the airflow.
If you mount at front/side then add additional intake fans at front/side, it will add more fresh air inside the case.
Now the question is, which one will be hotter and harder to cool in your system. CPU or GPU, in which I can't say for sure since I live in different place, nor do I have a RTX40.
If your CPU is doing fine thermally with AIO mounted on top, then go ahead use top, no one's gonna sue you for it.
If it's not, then you can try the alternative. Front or Side mounting.
Too much intake and not enough exhaust = Hot air lingers too long inside the case and gets reused a lot.
Too much exhaust and not enough intake = not enough supply of fresh air inside the case to be utilized.
We find the middle ground and then nudge it a bit toward positive / negative pressure.
I said to try it as is first because it's silly to buy, let's say... 5 more fans in advance for a something that might not happen at all.
That PC case have a lot of cooling placement which you can try later, kinda pointless to theorize before the stuffs arives and you can do a real life test.
Hot pockets will happen here and there but most often won't cause major issue, which IMHO the only solution for it is to use an open bench case. or Take off the side panel.
If that case and the cooling options it has is not enough to cool your system due to climate, then most likely your options is either open bench case or custom watercooling.
