13900k hitting 100c how to fix
Could someone tell me how to tame this beast ? xD Bios is way diff from my old 8700k even tho both are asus. power draw goes up to almost 300w but p cores only run at like 5.3 i have a CORSAIR iCUE H150i ELITE CAPELLIX
3 cores hit 100c some hit 91 to 97 the watercooler is working fine as far as i can see it as soon as i remove the load temp drop back into the 30ish ( while using cinebench to test ) sry xD
You should not measure temp with benchmarks, Temps wont be this high in gaming ad other loads, It should be 90C and below. But 13900K is a very hot CPU.
For farther assistance text me on Discord
Buy me a beer 🍻
ye i am reading about it but 100c on some cores and 300w power draw in cinebench is some crazy stuff 😄 what fking cooler can handel 300w constant
Custom loop.
Buy me a beer 🍻
Very few. Maybe  5. And your gonna need some loud fans.
AMD R7 5800X3D | Thermalright FC140 | No Fans | SYY-157
Asus Strix B550-XE | 32GB G.Skill Trident Z @ 3866C16 1.45v
EVGA RTX 3070 Ti FTW3 Ultra | WD SN850 1TB + SN750 1TB
EVGA SuperNova G+ 750w | Fractal Torrent Compact RGB
2 minutes ago, Dr0idGh0sT said:
Custom loop.
Maybe but even with a costum loop u would need atleast 2 360 rads to cool it
Arctic Liquid Freezer II 420mm and 3x be quiet! Silent Wings Pro 4 will manage it :D.
Buy me a beer 🍻
Was able to get it in line at 5300mhz perf core with -0.07000 - voltage offset now cinebench only pushes it to 90 ish and not 100 xD cyberpunk runs at 50c so all good i guess
Its actually good to measure temps with benchmarks but to take them as a worst-case scenario as like you said, gaming workloads wont get that high.  But it also depends what else you do on that machine, software video encoding can easily put a similarly high load on the CPU.
Router:  Intel Celeron N5105 (pfSense) WiFi: Zyxel NWA210AX (1.44Gbit peak at 160Mhz 2x2 MIMO, ~900Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~915Mbit down, 115Mbit up) + Three 5G (~900Mbit average down)
Folding@home Live Stats  Folding@home Recent WUs
Ye thats why i was worried my 8700k had a 280 aio and only hit like 80ish at 4.9ghz so when i started my new pc i was like waaaaaaaaaaaaaat when it insta went 100c but well i got it fixed by just undervolting and forcing it to 5.3ghz all p core now i only hit 90c max in cinebench thats still not perfect but i dont render i just game and in cyberpunk its only 50ish if even that i just got a 13900k to be futureproof for the next few gpus not cause i need that much cpu power atm
They're pushing the top-end chips really hard.  I have a 9900k and that seemed to be where they really started letting the power consumption/temperatures go wild.  That's partly down to the motherboard vendors though as some of them will default things like all-core turbo against what the chip is supposed to do, which is to reduce the clocks the more cores are in use.
 Share
