XPS 9360 Weird Noise & Running Hot
Solved by OhYou_,
the heat pipe is damaged yeah. it probably cracked somewhere and lost its vacuum, so the liquid inside stays more liquidy and then boils rapidly when it comes in contact with the hot af cpu. it doesnt use like water, so the boiling point is much less than 100c, causing this rapid phase change
just replace cooler and it will be fixed.
Featured Topics
Highguy ·
Posted in Troubleshooting0 -
2
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows0 -
2
Dedayog ·
Posted in Peripherals3 -
2
