Odyssey Neo G8, Lines on Blue/Orange when running at 240hz
Solved by Stahlmann,
Like @BetteBalterZen said it's a well known issue with Samsungs 240Hz monitors. If you set the monitor to a lower refresh rate it should be gone completely.
16 hours ago, BeeVa said:Awesome thanks! Hopefully there is a monitor out there to let my 4090 stretch its legs (without scanlines) lol
Afaik there are no other 4K 240Hz options on the market right now.
You can either get the Odyssey Neo G7, which only goes to 165Hz but is the same monitor other than that. (and doesn't have scan line issues)
Or go with a 42" 4K 120Hz OLED like the LG C2. These have even better picture quality and offer a very immersive experience for less money than both the Neo G7 and Neo G8.
