Side panel broke I need fast and permanent replacement
Solved by Middcore,
Unless you have pets or small children in your home who could be endangered by sticking their noses/paws/fingers inside the PC, I would simply do without the side panel and dust the system out more often.
The simplest "fix" you could probably make if your goal is only to keep "stuff" (dust, child fingers, etc.) out of the PC is just stretching long strips of duct tape across the open side of the case.
This, or any other "no cost" solution is of course going to look janky as hell, and also probably be a serious annoyance if and when you need to remove the "side panel" to work on the PC.
