Help! CPU ripped out of socket!
Solved by Crunchy Dragon,
AMD socket/CPU?
You're fine, provided no pins were damaged. Just make sure to run the PC a little bit next time so the thermal paste isn't hard. You can also twist the heatsink a little bit to separate it from the CPU before you pull it directly off. You can also just twist the CPU off the heatsink(don't drop it or bend the pins) and install it back into the motherboard.
This is a problem that has plagued AMD CPUs since before the AM2 socket.
