Audio feels like it's always left speaker "heavy"
Birblover12
I got gifted a pair of Edifier R1202T Speakers, and they sound amazing, though I found that the speakers sound or feel like the left speaker has significantly more "meat". Meaning, when playing a song, it sounds like the majority of the audio is coming through the left speaker. The right speaker is most definitely working, just maybe not as much as the left?
What could I potentially do to remedy this? Is this just a natural thing?
Keep in mind that I am sometimes wrong, so please correct me if you believe this is the case!
"The Nvidia Geforce RTX 3050 is brutally underrated"
Make sure that the angle and distance between you and the speaker is equal for both speakers.
If one speaker is closer to you than the other it can cause issues like this.
If one speaker is at a different angle (towards you) than the other that can cause such issues as well.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
It's a possibility that it's your hearing that's a problem. This can be determined by switching speaker around.
But as Vishera advised check speaker angle and distance first,
Do you have a subwoofer? Ik mine will cause phase interferance issues if it's not in the middle pointing directly towards me.
lumpy chunks
Expand to help Bunny reach world domination
(\__/)
(='.'=) This is Bunny. Copy Bunny into your signature to
(")_(") help him on his way to world domination.
 -Rakshit Jain
Nope, just the two speakers.
Simple problems have simple solutions, in your windows audio settings you can rebalance so that the right is louder
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
I think he's saying that the sound profile is "fuller" and "richer" on one vs the other
Every possible solution has already been mentioned that I can think of.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
I had something like that happen with my speakers, i even went and did a hearing test and the test was good.
At the end the issue was a faulty power switch on the right speaker which i fixed.
Funnily enough I thought my speakers were doing something similar. Turns out one of the panning features within Voicemeeter software had accidentally been clicked to the left speaker. (I almost always have voicemeeter open in the background and must have accidentally clicked the panning while trying to grab another window)
Double check all panning options, and if after trying all other recommended troubleshooting steps the pan is still unbalanced.. try panning the audio a bit to the right until it does sound balanced. I know it's not the best solution but would work for now until you had a chance to dig deeper into if it's something faulty with the speakers themselves.
If you ever suspect your hearing as the problem, just turn around so you have the loudspeakers behind you.
Its also a good idea to just try the speakers out individually and compare their sound profile, because sometimes the woofer fails or has a lower volume than the other. Its quite rare, but it happens.
I had similar issue where the right speaker is noticeably worse. Apparently my I got the speaker polarity wrong.
Yes, I realize you can plug + of the amplifier into - of speaker plug. They will work just fine, but the sound will be much worse.
