Samsung QE65Q60T and Denon DHT-S716H Soundbar ARC Setup
Ideally you plug the sound bar INTO the TV in the TV's ARC port.
Then you set the TV to output sound via ARC.
I would avoid indirect connections if possible or at least plug less important things into stuff that isn't the TV. Not the end of the world though, just often more finicky and potentially higher latency and/or reduction to lower HDMI specs.
The location of the OTHER things matters a lot less. The main case where it MIGHT matter would be if you have a PC or game console. It's usually ideal to plug those straight into the TV to lower latency (though some AVRs/soundbars might have their own ALLM which is fine) if there's ports available (especially for doing 4K 120Hz via HDMI 2.1).
As far as Dolby Digital Plus vs TrueHD, this probably doesn't matter much unless you watch Blu Ray discs - Netflix, Disney, etc. all compress their signal anyway.
