First build looking for reassurance and rec. (need mouse and keyboard suggestion)
Something like this gives you $150 for a case, or you can look at your budget to see if you can add a bit...
I took the CPU down to the 12400F, but upped storage to 1TB and the GPU to a 6700. It's a start and suggestions.
https://pcpartpicker.com/list/238xmr
PCPartPicker Part List: https://pcpartpicker.com/list/238xmr
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor ($166.99 @ B&H)
CPU Cooler: be quiet! Pure Rock Slim 2 CPU Cooler ($26.90 @ Amazon)
Motherboard: Asus PRIME H670-PLUS D4 ATX LGA1700 Motherboard ($129.99 @ Amazon)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($40.97 @ Amazon)
Storage: Intel 670p 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($59.99 @ B&H)
Video Card: XFX Speedster SWFT 309 Radeon RX 6700 10 GB Video Card ($319.99 @ Newegg)
Power Supply: Asus ROG THOR 850P 850 W 80+ Platinum Certified Fully Modular ATX Power Supply (Purchased For $110.00)
Total: $854.83
Generated by PCPartPicker 2022-12-03 10:21 EST-0500
