Is there a way to automatically close an application after it launches in startup?
Solved by Avocado Diaboli,
Create a batch or powershell script that closes the applications you want to close. Then open the task scheduler and create a task that runs after login. You can delay the task in the scheduler. Here's a guide on how to do that: https://www.maketecheasier.com/start-scheduled-tasks-with-delay-windows/
Featured Topics
alexfic ·
Posted in New Builds and Planning3 -
1
BryanOttawaDetroit ·
Posted in General Discussion1 -
2
2
GoStormPlays ·
Posted in WHALE LAN1 -
GoStormPlays ·
Posted in General Discussion5 -
9
jordan_wills ·
Posted in New Builds and Planning2 -
5
