I would like some help making revisions to my parts list
Rthatgames
Go to solution Solved by Pixelfie,
39 minutes ago, Rthatgames said:
Would it be worth saving the money and getting a system more like this
https://uk.pcpartpicker.com/list/RNsQxs
*forgot to change the fan over would use the silent wings fan.
I recommend going for the 12400 non F, especially if you have an AMD GPU. The iGPU can be used for acceleration when rendering and also has a better encoder for streaming compared to AMF or even Nvenc.
Also the B660M Gaming X is better for not much more.
PCPartPicker Part List
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor  (£196.99 @ Technextday)
Motherboard: Gigabyte B660M GAMING X DDR4 Micro ATX LGA1700 Motherboard  (£135.72 @ Amazon UK)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR4-3600 CL17 Memory  (£61.71 @ Amazon UK)
Storage: Crucial P2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£64.98 @ Amazon UK)
Video Card: *PowerColor Fighter Radeon RX 6600 8 GB Video Card  (£264.14 @ Amazon UK)
Power Supply: Fractal Design Ion Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (£81.27 @ NeoComputers)
Case Fan: Noctua A9 PWM 46.44 CFM 92 mm Fan  (£16.98 @ Amazon UK)
Total: £821.79
Generated by PCPartPicker 2022-10-31 08:53 GMT+0000
Budget (including currency): £900
Country: UK
Games, programs or workloads that it will be used for: light video editing. Some streaming and games such as minecraft and fifa, with the hope of trying some new more demanding titles
Other details I have a case and am planing on building a sleeper. So the 92mm fan is a must. And the case is m-atx as well
https://uk.pcpartpicker.com/list/yPk79r
12500 is not worth the price over 12400.
DDR5 for 12th gen is not worth the premium.
SSD is bad compared to SSDs around that price, picked a good one for ya.
6700 XT instead of 6600, budget reallocated from board, RAM, and fans.
PSU, higher quality PSU.
Noctua fans are not worth the price in this kind of build.
https://uk.pcpartpicker.com/list/wGhwKp
Motherboard: MSI PRO B660M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  (£159.93 @ Amazon UK)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£51.08 @ CCL Computers)
Storage: TEAMGROUP MP33 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£68.72 @ NeoComputers)
Video Card: PowerColor Fighter Radeon RX 6700 XT 12 GB Video Card  (£423.48 @ Ebuyer)
Power Supply: Phanteks AMP 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (£85.49 @ Overclockers.co.uk)
Case Fan: be quiet! Pure Wings 2 33.15 CFM 92 mm Fan  (£8.99 @ Amazon UK)
Total: £994.68
Generated by PCPartPicker 2022-10-31 07:54 GMT+0000
EDIT: the PSU from the original build is the same quality as this build, please disregard the comment on PSU.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI MSI PRO B760M-A WIFI DDR4
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
Total: £994.68
Total: £821.79
https://uk.pcpartpicker.com/list/nNTg4s
Managed to cram in a 13600k with a used 6700xt at this budget so no worries about platform upgrade for awhile
I have no idea if the gc 850w or txm gold (2021) 750w is better since theyre both at the same pricepoint
Yes buy the 6700xt used, some go as low as ~260£ on ebay
As for concerns on ram upgrade i chose klevv since they only use hynix, 3600 cl18 should be djr so buying another kit almost guarantees djr and if it isnt djr itll still work cause theyre still hynixes. Djr is actually pretty good so if you ever wanna oc for performance you can, though dont bother going gear 2 unless you are going 5200+, not sure if these bin djrs can do 5200+ but 4800 should be acheivable apparently. Though i advise sticking to gear 1 since high freq oc is just p a i n
