Completing bought parts
Solved by tkitch,
So, you need a Motherboard, Case, and PSU, at a minimum.
Do you have a CPU Cooler for the 2600?
Motherboard: B450 or B550 would be a good choice, leaving you the option to upgrade to Ryzen 5000 chips later.
Case: Will depend on motherboard & what you want
PSU: A decent 500W will run your build, but I'd look at 600-650W to leave room to upgrade to higher power use stuff later. Look for Tier B or better on the tier list:
https://cultists.network/140/psu-tier-list/
