Can a VA monitor ever look color accurate and color rich?
DSD27
14 minutes ago, e22big said:
It's important for colour critical works, basically the whole reason you want your display calibrate - so that on a good monitor with correct colour space, you know that your image will look the same if both calibrate theirs to 6500k.
I used to work in a publishing industry and caused really a lot back and forth when neither of us correct our display to the same temperature (we use paper as white point reference - yeah that was a while ago)
That the reason I said color accuracy is important only if you use it for productivity business usage.
For home use, it is good to get closer but not serious important to exact color match industrial standard.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
46 minutes ago, e22big said:
Wash out is probably not exactly the correct word, but the constrast seems to be lower than normal for some reason (know because there's a very noticable black raised, which can be fixed by adjusting digital contrast a little)
A bit lower contrast is normal when using ICC profiles. But we're normally talking about minor, mostly unnoticeable differences. For example 1000:1 uncalibrated, 950:1 calibrated.
but yeah, like you said, it could be just that most people are more more used to unclampped over saturated colour than accurate SDR. I personally prefer to hardware calibrate my display without using sRGB mode
Yes, hardware calibration is the best way. But sadly almost no monitor offers this option. That's one of the reasons i like LG TV's. They allow you to upload a 3D LUT, which makes them the most accurate consumer displays you can have.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
4 hours ago, Stahlmann said:
No. If you calibrate the monitor to sRGB, it will be clamped exactly to sRGB. There is no washing out. It might look that way because you're used to oversaturated colors, but it isn't. It's as you said, you're just used to oversaturated colors:
So the vast majority of ~99% sRGB IPS monitors have oversaturated colors? Have you seen how rich and vibrant they look?
I've had a few IPS monitors, even some not gaming but more professional oriented, they all looked like that on the Standard mode, which is the mode that usually has the less saturation.
Ryzen 5 2600X / ASRock Fatal1ty B450 Gaming K4 / G.Skill RIPJAWS V 16GB (2X8) 3000Mhz CL15 / Gigabyte RTX 2060 Super Gaming 8GB OC / Corsair RM650X 2018 / Crucial BX500 240GB / Seagate Barracauda 2TB 7200RPM Cooler Master MasterBox E500L /  ASUS TUF Gaming VG27WQ // Rog Orion / Corsair Harpoon RGB Pro / Cooler Master MasterKeys Lite L / Xbox One Red Sport  Special Edition Controller for Windows
No, most 99% sRGB monitors aren't oversaturated. But the ones that market over 100% sRGB are typically oversaturated. But how or if they're oversaturated depends on the model. Looking up reviews from RTINGS.com is a good source for this information.
All my monitors are wide gamut, so well over 100% sRGB. And yes, i can generally see if saturation is around what sRGB should be or if it's oversaturated.
Best I could do with this monitor is forget about the ICC profile. I've calibrated the gamma with windows calibration tool. And I now use NovideosRGB to clamp it to sRGB. I left NVIDIA control panel all at default. This looks better than any configuration involving the ICC profile.
Do you know if I need the wide gamut ICC profile to use HDR? Or is it irrelevant?
For HDR it's irrelevant. In HDR you're normally using the wide gamut either way.
Yeah. But I was thinking, shouldn't you need something to tell the OS that you have a wide gamut display? That's the job of the ICC profile provided by Asus.
Yet I've also noticed that Youtube videos ignore the ICC profile in SDR.
Yeah. But I was confused, shouldn't you need something to tell the OS that you have a wide gamut display? That's the job of the ICC profile provided by Asus.
But I've also noticed that Youtube videos ignore the ICC profile in SDR.
The OS doesn't really know if your monitor is wide gamut or not.
The OS just sends a color value to the monitor. Whether that monitor displays the correct one or an oversaturated one is up to the monitor. ICC profiles basically change the color value to a "wrong" color to compensate for the inaccuracity of your monitor so the end result is the correct color.
That's why hardware calibration is a great thing that's sadly not possible on most monitors. ICC profile overall have limited useability. Most apps don't use their information.
The main reason why the new Windows 11 HDR calibration feature is a big letdown is also that all this app does is create an ICC profile with very basic information like minimum brightness, maximum brightness and saturation.
And what happens to the ICC profile you already had with gamma calibration for SDR?
Didn't even know about it. Gonna try it...
Tbh i'm not sure. I haven't used them since i got into HDR displays (where i can use hardware calibration).
They could mess up HDR, or they could do nothing. I really don't know.
I found out right after. The HDR ICC profile is added separately as an "advanced ICC profile".
The HDR calibration tool improved my HDR massively, I can use HDR now. I thought HDR400 was jus terrible but it is actually usable after all.
Also, with HDR, the colors in SDR content look correct, not oversaturated and not washed out. Funny. Too bad there's always some yellowish tint in the desktop, otherwise I could leave it ON all the time.
