removing hard disk from imac and connect it to my main pc to read files
By
puppo
in Troubleshooting
in Troubleshooting
Solved by TylerD321,
Yes and no. Macs use a special file system that windows cannot see. When you put it into windows pc it will tell you to format it (don't do this). However, there are some work arounds you can use. A quick google search yields this result. https://www.makeuseof.com/tag/4-ways-read-mac-formatted-drive-windows/
xmegaMind1 ·
Posted in Troubleshooting0 -
AngelaHornung ·
Posted in Windows0 -
1
Arvo.k ·
Posted in General Discussion4 -
Eowen ·
MmmmTaterss ·
Posted in Troubleshooting1 -
SuperCookie78 ·
Posted in Graphics Cards2 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
