Fake Razer Viper Ultimate?
Viktor277
I had viper ultimate since 2021 which i lost when i was moving couple of weeks ago, and i bought another one but this one seems fishy. I registered it on the razer's site, feels like it should and sensor works the same, but the bottom of the mouse doesn't look like any viper from the web, and can't find anything about it? Mine doesn't have these holes on the charging contacts and says 20k dpi instead 20.000 dpi like on every other one, is this like the new batch of these where they cheap out on them or what
I doubt that any faker would put the actual Razer EU office address on the label which likely means that it's a version specifically for the EU market while all the images are for either the rest of the world or the USA considering the first image has the FCC logo which would be required for a version that is only sold in the EU market (the EAC takes its place).
I think you just got one from a different region, and I wouldn't bother worrying if it registered correctly on Razer's site. It looks like it's just a new revision of their European model, hence the EAC mark instead of FCC, RoHS, etc. and why there are some small differences in the markings and charging contacts.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
I bought the Razer Basillisk Ultimate earlier this year (EU) and the charging contact pads are the same as in the top picture and it says 20k DPI instead of 20,000 DPI.
So it's the mix of both pictures I guess? It also has the same adress for Hamburg in Germany as on 2nd picture.
Probably just from a different region. I have a Razer mouse, also says 20k DPI.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
