Guy's I need some help in laptop thing
I got the gigabyte G15 aorus I want help in how to stop pressing fn everytime  I want to higher the sound like the numpad keys f1till F9
Edited by HadiwithcappyCat
12 minutes ago, Mel0n. said:
I believe there's a setting in BIOS for that.
How to enter it also it's my brother laptop
1 minute ago, HadiwithcappyCat said:
I pressed f2 there is nothing in the bios that say enable action key 😞
Probably won't be what it's called.
Then, look up "Aorus 15 function key" or something
some laptops you just can't change this on
17 minutes ago, Mel0n. said:
Try esc, del, F9, or F12 on startup
Is this it
8 minutes ago, Mel0n. said:
nope that turns on the numlock key at boot, doesn't affect volume keys as you want
is it a laptop problem or bios
10 minutes ago, HadiwithcappyCat said:
Is this it
It may be in advanced. the setting might be listed as something like action keys, that is what it is in hp laptops at least
some BIOSes just don't have an option for that
1 minute ago, Mel0n. said:
your BIOS does not have it
Yes sadly I need now to keep clicking a Fn just for sound
What should I do
