LED Backlight on an IPS Panel But HOW??
Solved by mariushm,
Just now, Stahlmann said:IPS, TN and VA all are LCD backlit panels. They all need a backlight because the pixels themselves don't produce any light. The only current consumer display tech that doesn't use a backlight is OLED because every pixel can produce it's own light.
Transflective LCDs don't have backlight, they rely on light reflected off them. They're used for smaller size displays, for calculators, watches. This stuff doesn't work well for lots of colors, backlight is better..
Also, while not actual lcd monitor, eInk displays also don't have backlight ... it's pigments in the material being moved to create dots
