Best Fan Config for 4000D Airflow
Assuming your temps could be better, & all you have are 3 fans, through my own testing with my 4000D Airflow case (3 front intake fans, 1 rear exhaust fan, 1 top-rear exhaust fan, 1 tower CPU cooler with 1 fan), I found with exhausts, having either a rear or top-rear exhaust didn’t make much difference. Having both is better for reducing fan RPM (& potentially noise), but you can get away with one exhaust in either spot.
With intakes, the more the better, but if you had 2 for the front, place them in the two upper positions, so you cover your CPU & GPU (the front-middle fan should blow air under & over your GPU therefore helping to cool & dispel heat by pushing either out the back or up top.
So I’d say 2 in the front (upper & middle) as intakes, & 1 in the rear (or rear-top) as exhaust.
Check my threads where I’ve done a few tests in my 4000D Airflow (great case, as Linus featured in a recent video)…
https://linustechtips.com/topic/1430873-1-v-2-v-3-front-intake-fans-air-cooled-thermal-testing/
