Vertical vs Horizontal GPU water-cooling
Solved by RONOTHAN##,
I've seen a number of different vertical water cooled cards, it's not that uncommon. This should be fine.
Just make sure that the reservoir is going to be above the pump, else you are liable to kill the pump.
frozensun ·
Posted in Graphics Cards6 -
kisserik93 ·
Posted in Peripherals11 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory14 -
3
4
6
popularlion ·
Posted in Troubleshooting7 -
3
