Will a PCI Thunderbolt Card & Hub Fix This?
Solved by TheStyne,
Just now, jporteus said:I probably could, but I have always had bad experiences with USB extension cables. I'd also rather only have one cable for peripherals going from the PC to the desk if possible.
Fair enough, I've had lots of bad extension cables too. A thunderbolt dock/hub should solve your problem, but it's going to be a pretty big investment to get the card and a decent hub. You should also watch out for hubs that claim to be "Thunderbolt" when they're actually just USB. Because Thunderbolt 3/4 support USB communications, you'll often find hubs that claim to be thunderbolt, but are really just thunderbolt compatible. My Dell WD15, for example, is one of these docks. Just make sure to read all documentation about it before purchasing.
