First Build! Need Recommendations and Best Practices
Solved by RONOTHAN##,
26 minutes ago, Tomahawk9243 said:Virtual Machines
If this is what you plan on doing, the 12900K isn't really that good of a CPU choice thanks to it's distinction between performance and efficiency cores. If this is what you're doing, you should really be going 5950X instead or waiting for AM5 to release and going for the 7950X (or whatever it ends up being called).
Anyway, on to part recommendations. I will be using Saudi Arabian Newegg for pricing since it's what's on PCPP and I'm lazy.
- You'll need to change the motherboard to get something that will support the 5950X. Right now, the B550 Taichi is probably one of the best value high end boards on AM4, it's got basically every feature you could want and it's available for a pretty good price. I picked the Razer edition since it's the same price and I felt it looked better, but the only differences are aesthetic if you prefer the other one.
- Avoid MSI AIOs, they tend to break. Go for a dual tower air cooler for this system like the Deepcool AK620, it's cheaper, way more reliable, and will perform perfectly fine for a 5950X.
- You can get a cheaper kit of RAM.
- Unless you were planning on running the drives in RAID 1, you're better off getting a 2TB drive instead, it's cheaper and less parts to fail.
- The P360A is a pretty good case for the price, it should save you a bit.
- You can get a cheaper 3070 Ti.
https://sa.pcpartpicker.com/list/rjjPJM
This should do everything you wnat and be under budget.
