Need help for buying a film scanner
Solved by Blue4130,
5 hours ago, Lord Szechenyi said:I'm scanning them, so I can look at the pictures on my computers
I'm using a 4K tv as my display, and compared to 1080p it's actually quite a big step up in resolution for me, so I want to make sure that when I look at my pictures I can put them in fullscreen
I'm never going to print any of them though
Oh you don't need much then. I also run a 4k tv and my low res scans look fine.
I suggest the v750 since it can do 4 strips at a time. Loading and unloading the holders is the most tedious part, doing 1k of images will drive you nuts. I did 120 rolls of film after a trip and I was ready to jump out of the window halfway through.
