cpu stuck on cooler
Go to solution Solved by Priller,
Propane torch on the heatsink next to and around the CPU. After that twist and wiggle the cpu(with gloves on) while it's warm. It will come off but it may take a while.
hello people.
i was cleaning my old pc and pulled off the cooller and my amd cpu is stuck to it
it is really really stuck.  :(
any tips to get is off and not kill it
LY3KhYb.jpg?2
fractal define r4 - msi z77 mpower - i5 3570k 4.5ghz -alphacool water cooling+noctua -gtx 780ti-1323mhz-1.25v - corsair ax760i -vertex 4 120gb x2 - 840 evo 500gb - asus xonar dgx
corsair k70 - logitech g502 - sennheiser game zero - logitech z906 5.1 -samsung 46" iiyama 27"144hz - http://gabegaming.com/
https://linustechtips.com/topic/142746-cpu-stuck-on-cooler/
Was thermal adhesive used on it?
stock thermal adhesive 2005
my dad's old pc
try twisting the CPU
tried that did not work
wil a heat gun work to ?
https://linustechtips.com/topic/142746-cpu-stuck-on-cooler/#findComment-1905600
Does it move AT ALL?
https://linustechtips.com/topic/142746-cpu-stuck-on-cooler/#findComment-1905603
heat gun did the job thx
https://linustechtips.com/topic/142746-cpu-stuck-on-cooler/#findComment-1905615
I broke my socket 754 that way.
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/142746-cpu-stuck-on-cooler/#findComment-1913947
