This is called a "pull" configuration (as opposed to a "push" configuration). And yes. It's more or less identical performance.
Push can perform slightly better, but pull can be easier for dust management.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
@Future_Jacob
Everything has static pressure/airflow (0 static pressure means no air is moving). The difference is the more static pressure a fan is designed to achieve the more concentrated the air is and in the shape of a cylinder, and the further it goes through obstructions.
The less static pressure optimized a fan is the more the more air will be in a wider cone ( @jonnyGURU explained this nicely in the context for PSU cooling on the latest GamersNexus video).
The picture you linked above is just a visualization of this. When you're in pull, driving air through the radiator in that way, it still works fine, as the radiator is not very thick. (The pic below is from Techpowerup fan reviews, courtesy of VSG, who did the excellent reviews on his ThermalBench website previously)
14 hours ago, Dogzilla07 said:
@Future_Jacob
alright i just didnt know if the force that pulls faster through radiator goes both ways
11 hours ago, Blue4130 said:
That picture doesn't show static pressure. It only shows that a marketing department can use a graphic design software. 😉
It's a decent visualization of what a high static pressure optimized fan does, compared to low static pressure optimized. It causes misunderstanding about what happens before the fan, It's way overdone, as in not realistic to the actual fluid behaviour of the air, but it gets the point across. Yes the air is still gonna be turbulent and flail around, but that's a marketing slide, people mistake vortices for turbulence, and assume turbulence is bad for performance, when in truth is the opposite, but you can't explain that in a single picture.
I do completely agree with you that having an obstruction present on the picture would be much better, and would bring greater clarity without affecting the complexity.
Air in a case behaves like water in hose/aquarium, air doesn't really move, temperature is imaginary and fake xD. I love absolute truths, as much as the next guy but at the end of day, a balance is needed, when even the schooling system doesn't do how stuff truthfully works until one is doing their masters and even doctorate/end-specialization in physics/chemistry/material sciences.
Yeah, it's fine, as long as you don't have huge chunky radiators.
How does concentric circles and three arrows merging into one arrow show high static pressure?
probably depends on fan. back then any testing was off and came to the concussion it was not worth the argument over. but gn dose have a tool to do things like that but we will have to wate.
the way i under stand it is it can force more air and not have so much air fly back out so the gaps of the blades are smaller. the  nosie blocker enloops are to the exstream but still think thows was marketing.
