Need help chosing a new monitor LG vs LG vs Acer predator.
thorsbaron
Hi!
Im in a market for a new monitor and i cant make up my mind.
Any help would be appreciated.
I have 3 choices.
1.LG 34'' UltraGear 34GN850 QHD Curved Nano IPS 160 Hz
2. LG 34'' UltraGear 34GP950G QHD Curved Nano IPS G-Sync (180 Hz)
3. Acer 34" Predator X34GS IPS 21:9 Curved 180 Hz
No:1 is the cheaper option
No:2 and 3 are the same price for me.
I use my montitor for gaming, movies and shows.
My spec is:
CPU: AMD Ryzen 5 2600X
MOBO: ROG STRIX B450-F GAMING
RAM: CORSAIR VENGANCE 4X8 GB 3000MHz CL15 (32GB Total)
GPU: ASUS GeForce RTX 2070 8GB ROG STRIX GAMING OC
POWERSUPPLY: Corsair RM750X 750W v2
STORAGE: 3 SSDs, 2 M.2s, 1 HDD.
WINDOWS 10
Thank you
https://www.rtings.com/monitor/tools/compare/lg-34gn850-b-vs-lg-34gp950g-b/13261/21824?usage=3623&threshold=0.10
I'd go for the 180Hz one. Better overall and G-Sync direct support instead of Freesync.
Unfortunately, RTings doesn't seem to have that Acer monitor tested, but supposedly it's the same panel underneath as the 34GP according to some reddit comments.
