should i swap my monitor for an identical AOC refurb?
The Torrent
Hi,
speakers on my monitor are broken, AOC AG352UCG6, and i dont use the speakers anyway.
Anyway, i have used the monitor for almost 3 years straight and i can get it replaced under warranty. likely they will replace it with a refurb or something.
Now, my monitor works (as much as i need it to). display is all fine and everything. the new monitor may end up possibly developing a fault sooner than this one? Who knows how it was treated pre refurb? I mean i guess its probably still been used less than my current monitor though. its also effort to un wall mount my current monitor replace it, then re-wall mount.
What do you guys think i should do? Should i swap my basically working 3 year constant use monitor for a possible refurb but likely newer than my current monitor?
The warranty is close to being out so if a further fault develops in either of them its spending £££ time.
i wouldnt swap in this situation
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Any reason why?
44 minutes ago, The Torrent said:
Any reason why?
ur monitor is functional, you don't use the speakers, it's a lose:lose situation
New monitor with less total screen on time may last longer though?
that's up to u to decide, u know how ur monitor works, whether or not the one they send you works is a diceroll.
my gpu fan broke, after doing some research i woulda gotten a refurb 2080ti or a 3070 after paying a triple deposit (if it was a 3070), and there were endless horror stories for the refurbs.
If they swap it with a Refurb, that depends on how the Refund/warranty policy works.
if your warranty is almost over, and you can get a Refurb for FREE, then go with the refurb, it might last 2 years, it might last less. Anything is often better than nothing
Last time I claimed warranty on a Monitor, { it was lost/delayed in transit with 4 weeks} Thus I had gotten a FULL refund, and just bought a new display. [Same series, slightly different model [adjustable feet/height, instead of single height] with as reason, that that one was cheaper, and not sold by a reseller that uses the same platform to sell their display's]
║__________________║ hardware_____________________________________________________ ║
║ cpu ______________║ ryzen 9 5900x_________________________________________________ ║
║ GPU______________║ ASUS strix LC RX6800xt______________________________________ _║
║ motherboard_______ ║ asus crosshair formulla VIII______________________________________║
║ memory___________║ CMW32GX4M2Z3600C18 ______________________________________║
║ SSD______________║ Samsung 980 PRO 1TB_________________________________________ ║
║ PSU______________║ Corsair RM850x 850W _______________________ __________________║
║ CPU cooler _______ ║ Be Quiet be quiet! PURE LOOP 360mm ____________________________║
║ Case_____________ ║ Thermaltake Core X71 __________________________________________║
║ HDD_____________ ║ 2TB and 6TB HDD ____________________________________________║
║ Front IO__________   ║ LG blu-ray drive & 3.5" card reader, [trough a 5.25 to 3.5 bay]__________║
║ OS_______________ ║ Windows 10 PRO______________________________________________║
