Will the cooler fit?
Darknighterror
Hello Guys,
im planning on buying a cpu cooler. My case manuel says, it can be up to 163mm high. Im currently thinking about buying one thats 160mm (including fan). Will it fit without any problems or would you recommend buying one thats less tall?
With larger coolers in a tower configuration, your fans will generally mount facing case front (side mount), which won't be a factor in height... such as my Scythe Mugen 5, pictured here... FWIW, the Mugen 5 Black Edition pictured here is 154mm total height.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
35 minutes ago, Darknighterror said:
Hello Guys,
What case and what cooler?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Case is a nanoxia deep silence 3, cooler would be a Noctua NH-D15S
RIP. I was hoping it would be something more common so I could look for PCpartpicker builds using the same combo to confirm.
That's fine. A case that lists 163mm of clearance should fit a cooler up to 163mm in height.
The nahbluglbudfjkfdjksa deep silent what the heck". Has anyone else heard of this ?
CPU-AMD Ryzen 7 7800X3D GPU- RTX 4070 SUPER FE MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Maya+ 4k Dongle+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
It's an older, Fractal Define clone-ish thing. Came out around 2014 and did get reviewed by a lot of known sites (tweaktown, techpowerup, etc.) in the day.
Ok, im just gonna get that cooler and try it. Meanwhile I found out, that every retailer and even the official product page say a 165 will fit, while my (printed,lol) manual says 163 mm.Sounds a bit weird to me, but if 165 is true, I dont mind 🙂
In my experience these things usually have a little more wiggle room in real life than the specs suggest, so I think if you have a 3-5mm margin between the cooler height and what the specs say the max cooler height for the case is you'll probably be fine... as long as you don't need to push the fans up to accommodate tall RAM or anything, of course.
