Shipping courier threw my motherboard, how should I test if it works?
So i just recently purchased a gigabyte b450 motherboard. I saw from my house's CCTV footage that the courier has carelessly threw it over my gate.  How should I test that it still works? The problem is that I dont have a compatible CPU nor RAM for it right now, and they probably wont arrive until the deadline for when I can claim the insurance on it passes. Hence I need a way to test if the motherboard is still functioning and all the components are working well without most of the actual parts. I have a compatible graphics card though, and sata drives but I'm guessing that wont be to helpful. Can someone assist me with this? Thanks beforehand.
Now i see why some ppl like prebuilts :0
(Also just as a venting section for myself, the package box comically landed on the right side up, which meant that the courier somehow manage to miss the all capital large font text and symbol saying fragile lol.)
Its fine
As someone in upstream logistics i can assure you it was handled far worse way before that.
If you cant see any physical damage on the board its fine, especially if its packed in an insert inside the box.
He did try his best, that doesn’t look like a hard hit as well. Just use it and see if it works, personally I doubt there will be anything wrong.
You can't test it without a CPU iirc.
Also, that's not that bad of a toss. He was just trying to get it to you. Products are tested so that they're not damaged with light throws like that. It's part of the whole reason it comes in a box with, usually, a couple of layers to it.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
